02-12-2009 11:15 PM - edited 03-04-2019 03:33 AM
Hi Everybody,
I am configuring and testing EIGRP. I facing instance as described below:
I have 3 Router configured as shown in diagram runing EIGRP.
I have 3 Subnet 172.16.1.0 / 24, 172.16.2.0 / 24, 172.30.1.0 / 24 in Router A
1. When I configure "no auto-summary" in Router A, I am seeing the Routing table of Router C that 172.30.1.0/24, 172.16.2.0 / 24, 172.30.1.0 / 24.
2. When I configure "auto-summary" in Router A, I am seeing the Routing table of Router C that 172.30.0.0/16, 172.16.2.0/24, 172.30.1.0/24.
Why 172.16.1.0/24 and 172.16.2.0/24 is not getting summarized as like 172.30.1.0/24.
I Expected 172.16.1.0/24 & 172.16.2.0/24 will also be summarized to 172.16.0.0/16 like it happended in 172.30.1.0/24 changed to 172.30.0.0/16
Can you please help me to know about this behaviour
R.B.Kumar
02-12-2009 11:38 PM
How are you getting the route installed at RouterA - network statements or redistribution ?
EIGRP will not auto-summarize external routes unless there is a component of the same major network that is an internal route
Narayan
02-13-2009 12:05 AM
Hi Narayan,
I am not redistributing. Networks 172.30.1.1/24, 172.16.1.0/24,172.16.2.0/24 are all directly connected
Any clues..?
R.B.KUMAR
02-13-2009 12:08 AM
can you post the relevant configurations of the routers?
Narayan
02-15-2009 12:25 PM
I configured this in my lab and here are my results.
no auto-summary
C(config-router)#do sho ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
172.16.0.0/24 is subnetted, 3 subnets
D 172.16.30.0 [90/2809856] via 10.1.3.1, 00:00:14, Serial0/0
D 172.16.1.0 [90/2809856] via 10.1.3.1, 00:00:14, Serial0/0
D 172.16.2.0 [90/2809856] via 10.1.3.1, 00:00:14, Serial0/0
10.0.0.0/24 is subnetted, 2 subnets
C 10.1.3.0 is directly connected, Serial0/0
D 10.1.2.0 [90/2681856] via 10.1.3.1, 00:00:14, Serial0/0
with auto-summary
D 172.16.0.0/16 [90/2809856] via 10.1.3.1, 00:00:07, Serial0/0
D 10.1.2.0 [90/2681856] via 10.1.3.1, 00:01:44, Serial0/0
02-15-2009 12:26 PM
Post your config's.
02-16-2009 07:24 AM
Actually i face the similar problem. So at the begining i was configuring manual summarization. Then a CCIE told me that summarization is not so importand if you have a network less than 100 routers. Also he adviced me that i should avoid auto-summary because sometimes it causes problems . I do not know. They know better.
Good luck
Moses.
02-16-2009 12:49 PM
Auto-sum will cause problems.
For example you have 10.2.1.1/24, 10.3.1.1/24 and 10.4.1.1/24.
With auto-sum your routing tables will show 10.0.0.0/8.
With no auto
you will see this
10.0.0.0/24 is subnetted, 3 subnets
10.2.0.0
10.3.0.0
10.4.0.0
