Which ASA
Feb 12th, 2009
I want to set in my network an ASA which can do at the same time:
-Firewall
-VPN
-IPS
-Content Security
-VPN SSL
All for a network with around 500 users.
Many thinks.
eddie.mitchell@... Fri, 02/13/2009 - 06:19
Without knowing your network throughput requirements and just guessing, I'd probably say you'd be looking at a 5520.
cdusio Fri, 02/13/2009 - 07:34
You can't do IPS and content security on the same ASA...
cdusio Fri, 02/13/2009 - 07:36
What's the throughput requirement? The ssm modules just use the power from the chassis they are plugged into. The limitation really comes from traffc flowing through the box.
Fishow8472 Mon, 02/16/2009 - 06:33
I need more information. And what do you want to know with your describe?
