EIGRP
Answered Question
Feb 13th, 2009
I connected two router A (IP ADD 172.26.16.14) and B (172.26.16.12 )and running EIGRP b/w two router,both the line protocol is up but not learning any network from A to B.The router configuration is as follows.
Router A =====================================
interface Loopback1
ip address 172.16.10.1 255.255.255.0
interface Loopback2
ip address 172.16.20.1 255.255.255.0
interface Loopback3
ip address 172.16.30.1 255.255.255.0
interface Loopback4
ip address 172.16.40.1 255.255.255.0
interface Loopback5
ip address 172.16.50.1 255.255.255.0
interface FastEthernet0/0
ip address 10.97.37.252 255.255.255.0
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.97.38.1 255.255.255.0
interface Serial0/0/0
description PE40-AIRTEL-NOC [10.20.30.2/29]
ip address 172.26.16.14 255.255.255.0
clock rate 2000000
interface Serial0/0/1
ip address 20.20.20.1 255.255.255.0
encapsulation frame-relay
clock rate 2000000
frame-relay map ip 20.20.20.2 100 broadcast
frame-relay lmi-type ansi
interface Serial0/1/0
interface Serial0/1/1
ip address 192.168.10.1 255.255.255.0
router eigrp 10
redistribute static
network 10.0.0.0
network 172.16.0.0
network 192.168.10.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.97.37.254
Sh ip route
Gateway of last resort is 10.97.37.254 to network 0.0.0.0
20.0.0.0/24 is subnetted, 1 subnets
C 20.20.20.0 is directly connected, Serial0/0/1
C 192.168.10.0/24 is directly connected, Serial0/1/1
172.16.0.0/24 is subnetted, 5 subnets
C 172.16.50.0 is directly connected, Loopback5
C 172.16.40.0 is directly connected, Loopback4
C 172.16.30.0 is directly connected, Loopback3
C 172.16.20.0 is directly connected, Loopback2
C 172.16.10.0 is directly connected, Loopback1
172.26.0.0/24 is subnetted, 2 subnets
C 172.26.16.0 is directly connected, Serial0/1/0
D 172.26.8.0 [90/2172416] via 192.168.10.2, 19:23:59, Serial0/1/1
10.0.0.0/24 is subnetted, 7 subnets
D 10.50.50.0 [90/2297856] via 192.168.10.2, 1w1d, Serial0/1/1
D 10.40.40.0 [90/2297856] via 192.168.10.2, 1w1d, Serial0/1/1
D 10.30.30.0 [90/2297856] via 192.168.10.2, 1w1d, Serial0/1/1
D 10.20.20.0 [90/2297856] via 192.168.10.2, 1w1d, Serial0/1/1
D 10.10.10.0 [90/2297856] via 192.168.10.2, 2d01h, Serial0/1/1
C 10.97.38.0 is directly connected, FastEthernet0/1.1
C 10.97.37.0 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 10.97.37.254
Router B======================
interface Loopback0
ip address 10.10.10.10 255.255.255.0
ip address 10.90.90.1 255.255.255.0
speed auto
interface Serial0
ip address 172.26.16.12 255.255.255.0
clock rate 64000
router eigrp 10
network 10.0.0.0
network 172.26.0.0
no auto-summary
Sh ip route
Gateway of last resort is not set
172.26.0.0/24 is subnetted, 1 subnets
10.0.0.0/24 is subnetted, 2 subnets
C 10.90.90.0 is directly connected, FastEthernet0
C 10.10.10.0 is directly connected, Loopback0
Correct Answer by royalblues about 7 years 11 months ago
Router A is missing the network command under EIGRP
network 172.26.0.0
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Fri, 02/13/2009 - 00:26
network 172.26.0.0
Narayan
ntmanjunath Fri, 02/13/2009 - 00:44
Oh..I have not observed this since my route A was rebooted and not saved the config.
Thank you
