Alert on single handset unregistered ?
Feb 13th, 2009
I know there is an e-mail alert configured in RTMT to trigger when registered handsets drop by x%
However, I need to configure an alert when any single device is unregistered. As I have 700+ devices, setting an alert on "1%" unregistered is not sensitive enough. Setting the alert to "0%" seems to make the default setting if "10%" apply.
I've got a problem with handsets going missing. For the short-term I wanted notification if any are disconnected. I understand that in the long term, alerts like this would be too overwhelming and that the alerts in RTMT are to identify significant service issues, but have a short-term requirement to monitor this closely.
Does anyone have any suggestions ?
Jaime Valencia Fri, 02/13/2009 - 07:42
a message is logged in the app log when a phone un-registers.
if it happens you can simply look at it and it'll have device, time, reason code, etc
if this helps, please rate
ajenks Tue, 02/17/2009 - 03:36
Thanks Java, but this is 6.1, so it's not a windows server. I assume there is equivalent log in 6.1 aswell - but I wanted real-time alert (like an e-mail). I need to detect this condition quickly, rather than review logs on a regular basis.
If this was a Windows platform, I might be able to find something that would trawl the event logs and generate an SMTP alert, but not sure where to start on this platform.
