02-13-2009 02:00 AM - edited 03-04-2019 03:33 AM
Hi, I am trying to configure LFI on my two routers connectected point-to-point but I cannot ping the next router.
I am still on my learning phase.
please assist here below are my configs:
router 1 (2821)
class-map match-any realTime
match any
policy-map Mpho
class realTime
bandwidth 500
interface Serial0/0/0
ip address 165.x.x.x.255.255.252
encapsulation frame-relay
no keepalive
clock rate 8000000
frame-relay traffic-shaping
frame-relay interface-dlci 100 ppp Virtual-Template1
class Mpho
interface Virtual-Template1
bandwidth 500
no ip address
no peer default ip address
ppp multilink
ppp multilink interleave
ppp multilink fragment delay 20
service-policy output Qos
router rip
network 165.148.0.0
network 192.1.1.0
map-class frame-relay any
map-class frame-relay Mpho
Router 2 (3845)
match any
policy-map Mpho
class realTime
bandwidth 500
bandwidth 2000
no keepalive
class Mpho
max-reserved-bandwidth 100
bandwidth 500
no ip address
ppp multilink
service-policy output Mpho
router rip
network 165.148.0.0
network 192.2.1.0
map-class frame-relay realTime
02-13-2009 02:22 AM
If they are connected directly, try adding the following to any one of the routers
Router1
frame-relay switching
frame-relay intf-type dce
Narayan
02-13-2009 02:41 AM
I just realised you havent created a multilink interface
You would also require to modify the configuration as below
Router1
interface multilink 1
ppp multilink
ppp multilink group 1
ip add 165.x.x.x.255.255.252
no ip address
Router2
ppp multilink
no ip address
Narayan
