is it possible to install a 9- or 16-port HWIC on ISR 2821.
Feb 13th, 2009
I am about to place an order for a 2821 router but I need to be sure if i will able to install a 9- or 16-port HWIC to serve as layer 2 switch for the network I will setting up at my remote site.
royalblues Fri, 02/13/2009 - 03:45
You can use NM-16ESW on the 2821 for the LAN.
I dont think there is a HWIC card available for the LAN
Narayan
