UC500 incoming digit prefix
Answered Question
Feb 13th, 2009
I am working with a customer who has a UC500 connected to a SIP trunk in the UK. We are having a problem with the SIP provider because the removing the leading zero on the incoming number so when the call come through it is displayed without the first digit on the IP phone display. The problem for the user is they cannot press redial as the outgoing number is then incorrect. Is there a way of prefixing an inbound number and adding the missing digit?
Ian
Correct Answer by paolo bevilacqua about 8 years 5 months ago
Thank you, I've rated your post as you took further time on an already resolved issue.
Overall Rating: 5 (4 ratings)
paolo bevilacqua Fri, 02/13/2009 - 04:39
  • Hall of Fame,
    Founding Member
voice translation-rule 10
rule 1 // /0/
voice translation-profile add0
translate calling 10
dial-peer voice XX voip
incoming called-number ZZZ
translation-profile incoming add0
ianwarb Fri, 02/13/2009 - 04:49
I will try this, thank you very much for being so prompt
paolo bevilacqua Fri, 02/13/2009 - 04:50
  • Hall of Fame,
    Founding Member
You are welcome, remember to rate useful posts with the scrollbox below.
ianwarb Fri, 02/13/2009 - 05:52
This doesn't seem to be working. I have configured it as you suggested but am still dropping the zero. Can I post you my config?
paolo bevilacqua Fri, 02/13/2009 - 05:57
  • Hall of Fame,
    Founding Member
Possibly it is not matching the DP.
Do you have a single voip DP with incoming called-number ?
ianwarb Fri, 02/13/2009 - 06:12
Not sure what you mean by DP. We have a series of DDI numbers being delivered over a SIP trunk with the following config
voice translation-rule 4
rule 1 /441612413849/ /3849/
voice translation-rule 5
rule 1 /441612413850/ /3850/
voice translation-rule 23
rule 1 /441612417746/ /7746/
rule 2 /441612417747/ /7747/
rule 3 /441612417748/ /7748/
voice translation-rule 24
rule 1 /441612413840/ /3840/
rule 2 /441612413841/ /3841/
rule 3 /441612413842/ /3842/
rule 4 /441612413843/ /3843/
rule 5 /441612413844/ /3844/
rule 6 /441612413845/ /3845/
rule 7 /441612413846/ /3846/
rule 8 /441612413847/ /3847/
rule 9 /441612413848/ /3848/
rule 10 /441612413849/ /3849/
voice translation-rule 30
rule 1 // /0/
voice translation-rule 410
rule 1 /^9\(.......)\)$/ /441\1/
rule 2 /^9\(.*\)/ /\1/
voice translation-rule 1111
rule 1 /\(....\)/ /44161241\1/
rule 2 /\(....\)/ /44161241\1/
rule 3 /\(....\)/ /44161241\1/
rule 4 /3849/ /441612413849/
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
rule 1 /441612413360/ /6000/
voice translation-rule 2222
voice translation-profile CallBlocking
translate called 2222
voice translation-profile FAX_Called
translate called 4
voice translation-profile MainDDI_Called
translate called 24
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate calling 1111
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
translate calling 30
dial-peer voice 1000 voip
description ** Incoming call from SIP trunk **
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number .%
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
description ** Outgoing call to SIP trunk (Generic SIP Trunk Provider) **
translation-profile outgoing PSTN_Outgoing
destination-pattern 0T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1002 voip
corlist outgoing call-local
description ** star code to SIP trunk **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1004 voip
description description ** Outgoing call to SIP trunk (Generic SIP Trunk Pro
destination-pattern 9T
voice-class codec 1
dtmf-relay rtp-nte
no vad
thanks
Ian
paolo bevilacqua Fri, 02/13/2009 - 07:15
  • Hall of Fame,
    Founding Member
Hi, as Nick suggested, do the debug to check call is hitting the right DP (Dial Peer).
ianwarb Mon, 02/16/2009 - 02:51
Guys
I got this working using:
rule 1 /^/ /0/
Then adding this to my main incoming DDI dial-peer
Thanks very much for your input
Ian
paolo bevilacqua Mon, 02/16/2009 - 02:55
  • Hall of Fame,
    Founding Member
Interesting. For my curiosity only, could you confirm if // /0/ works as well ?
Correct Answer
paolo bevilacqua Mon, 02/16/2009 - 04:27
  • Hall of Fame,
    Founding Member
Nicholas Matthews Fri, 02/13/2009 - 05:57
  • Red, 2250 points or more
Try this configuration:
rule 1 /^\(.*\)$/ /0\1/
voice translation-profile add-zero
translate calling 1
dial-peer voice 1 voip
translation-profile incoming add-zero
You may want to 'debug voip dialpeer' to see if you're hitting the dial peer you expect to.
-nick
paolo bevilacqua Fri, 02/13/2009 - 06:04
  • Hall of Fame,
    Founding Member
Nick, you have rule 4 called as 1 from profile.
The regexp isn't necessary for prepend. // matches the "virtual nothing" in front of number.
Nicholas Matthews Fri, 02/13/2009 - 11:27
This is probably correct. I'm kind of a stickler because I too many stupid things happen because of assumptions, so I generally hard code things like this so there isn't any room for error.
-nick
paolo bevilacqua Fri, 02/13/2009 - 11:30
  • Hall of Fame,
    Founding Member
Nick, it's not an assumption, it works and it makes sense too. Try it once and you will have less chances of typing wrong with all the funny characters in a fully specified match and set rule.
