02-13-2009 04:48 AM - edited 03-04-2019 03:33 AM
hi all,is it possible for my adsl router to dial up and then bridge to the lan interface ? I want to have a public IP on my firewall that is inside the lan.
02-13-2009 04:53 AM
02-13-2009 06:38 AM
I'm not sure if the posted link will help you. Your original post implies that you have a router in front of your cisco router. If that's the case, you'll have to find out how to put your ADSL router in bridging mode. There are several manufacturers. I have a 2wire DSL modem that can't be bridged, but I forward everything to a DMZ interface which then passes my public address to my 871W. Everything works great.
HTH,
John
02-13-2009 07:17 AM
The OP has a cisco ADSL router - see title "C800". The config for that is in the link I provided.
