CUCM 7 - Autoregistration and Extension mobility
Feb 13th, 2009
We have to deploy 300 IP phones.
Customer uses "Extension Mobility" service and a profile has been created for all new users.
For the deployment, I want to use "Auto Registration" function. (More convenient for 1st level support given by customer himself)
Is there a solution to subscribe automatically to the "Extension Mobility" service and enable Extension Mobility on a phone registered in the CUCM 7.0 with "Auto Registration"?
I would like to have phone ready for login (ext mobility) once they are registered without having to use BAT tool.
Any suggestion?
Thanks in advance.
Jaime Valencia Fri, 02/13/2009 - 07:43
auto-registration does not provide that, if you need to have the phones with EM use BAT
if this helps, please rate
dfragp Fri, 02/13/2009 - 08:19
Ok, thanks.
So, there is no way to manage only profiles without taking care about physical phone?
The idea was, in case of hardware failure, to just replace the phoneset and log on the new one with EM profile (can be done by a user without any access right on the CCM web page).
There is no solution to do that?
Jaime Valencia Fri, 02/13/2009 - 08:46
auto registration is only for the most basic config so a phone can make calls, advanced configurations need to be done manually or using BAT
replacing the phone needs access to CCMadmin, BAT or basic config via auto-registration.
those are the options
Bekzod Fakhriddinov Thu, 10/20/2016 - 07:26
so in his case he can't use bulk add phones with dummy mac addr then auto register them with TAPS so will need to get all mac addr of the 300 phones ?  would be very easy if it 'd possible to add phones w/ dummy mac and then let users to login w/ their extension mobility profiles...
Jaime Valencia Thu, 10/20/2016 - 15:56
If you want people to always use EM, you can just auto-register the phones with a basic config, and enable EM as an enterprise subscription.
