CAD Screen Popups
Feb 13th, 2009
Hello
I have a problem with screen popups not poping up on CAD Agent Desktops. It is an intermitent problem where out of the total calls received about 50% don't have popups.
Has anyone had this problem or anyone has any idea.
All help appreciated
Victor
david.macias Fri, 02/13/2009 - 06:24
  • Blue, 1500 points or more
Simplify the problem. Is this happening to all PCs? Do all PCs only get 50% of the pops? Also, what does the workflow do which generates the pop?
david
rhobab Fri, 02/13/2009 - 06:54
Hello David
Yes this basically seems to happen on all pcs. It is intermitent. It may be working and all of a sudden one or two calls without popups.
The workflow contacts an application called Callme that provides the web screen
Victor
