UCM BE 6.12 and Mobility
Feb 13th, 2009
I am looking for the ability to call one extension and have multiple outside extensions ring at the same time as the extension. Is this possible with just Unified Communications Manage Business Edition 6.12. Would you need a mobility server to do something like this? Would functionality like this be built into a version 7 server.
Aaron Harrison Fri, 02/13/2009 - 09:04
This used to be a seperate product (MobilityManager), but since CM6.x it's built into the standard product.
You don't need a seperate server, but each user you enable for the feature uses up an extra DLU (Device License Unit).
Aaron
Please rate helpful posts...
robbie.teo Tue, 03/03/2009 - 00:45
I'm using CM 6.1 connected via FXO.
How can i configure to allow multiple phones to ring at then same time? Thanks
gogasca Tue, 03/03/2009 - 01:02
check features guide for cucm 6.x
fxo r not supported for mobile connect. you need t1 pri.
