MDS 9509,9222i & 9234 configuration with HP System Insight Manager
I have enabled the Https(Cimserver) using a dummy ssl certificate. Still my central management server (HP SIM) doesn't recognizes the switch to be a Storage Switch.
when i run the identification query, it stops at " CIM_RegisteredProfile"
stephen2615
Level 3
Level 3
I know there might be issues with cimserver and different versions of SMI-S solutions. SAN-OS 3.2 uses 1.1 and 3.3 and above uses 1.2. The changes are considerable and can make some SMI-S system not work well. I don't know if NX-OS is supported yet.
I don't use HP SIM so I really can't say for sure but its worth checking on what is supported.
