02-13-2009 06:45 AM - edited 03-04-2019 03:33 AM
I read that by default there are different Tx Queue Sizes for different queues available.
1. Can we change the Tx Queue Size of Priority Queue ?
2. I guess we can change the Tx Queue Size of Standard Queues by <<wrr-queue bandwidth X Y Z >> command. Plz confirm..
Thx,
GP
02-13-2009 08:30 AM
Hello Gaurav,
in C6500 for its high modularity capabilities and default values are linecard model dependent.
However, you should be able to tune them within the allowed range for a specific linecard.
For some linecards there can be even more varations depending if they mount a DFC or not (not sure of this but it can happen)
see
and table 41-3
Weighted Round Robin (WRR)-WRR does not explicitly reserve bandwidth for the queues. Instead, the amount of bandwidth assigned to each queue is user configurable. The percentage or weight allocated to a queue defines the amount of bandwidth allocated to the queue.
Hope to help
Giuseppe
02-15-2009 09:21 PM
say on Sup 10G 3C supervisor port , can we change the TX queue value for Strict Priority class ?
thx
GP
02-16-2009 05:01 AM
Hello Gaurav,
see table 37-2 in following doc
notice that the queues structure changes if you decide to disable the GE ports on the supervisor linecard
for tx queues the structure is
1p7q4t
1p7q4t indicates the following:
-One strict-priority queue
-Seven standard queues, each with four thresholds, each threshold configurable as either WRED-drop or tail-drop
this should mean that you cannot choice the size of the priority queue
Actually a strict priority queue is served until the queue is empty: this is the meaning of strict priority queue so its size is in some ways less important then in normal queues
Hope to help
Giuseppe
