Upgrade CCM 4.1 To 6.1 Add Node
Feb 13th, 2009
I'm collapsing 2 clusters (4.1) to 1 and need to add a second subscriber to the surviving cluster before running DMA. Do I have to actually build the second subscriber completely and add it via CCM Admin GUI or can I simply add it using the Admin GUI (much like you could add phones not registered). Which would fulfill the licensing requirement for the upgrade?
shell99101 Fri, 02/13/2009 - 08:16
I just went through the same process and was able to work with the licensing group by supplying them the serial numbers of the servers and they sent me the server license file for the software license and the node license. As for the DLU's I had to fill out a worksheet and send it back to them. I was able to avoid running the DMA since it was two clusters migrating to one.
Mike
mwheinz Fri, 02/13/2009 - 08:31
So how did you replicate the database to the new version 6 cluser, BAT and "stare and compare"?
Thanks!
