Pulling CM End Users into Unity- CUCMBE 7.0
Feb 13th, 2009
I have all of users in the End User group. When I go to the Unity side, is there a way to pull them into the Unity as VM subscribers?
Thanks in advance,
George
Jaime Valencia Fri, 02/13/2009 - 09:20
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, there is a separate set of instructions for BE systems for integration and import of users.
here you have all the guides for a BE system including the CUC: User Moves, Adds, and Changes Guide for Cisco Unity Connection in Cisco Unified CMBE Release 7.x
Cisco Unified Communications Manager Business Edition
Maintain and Operate Guides
http://www.cisco.com/en/US/products/ps7273/prod_maintenance_guides_list.html
java
if this helps, please rate
