Default-information Originate Route-map
Feb 13th, 2009
I'm trying to figure out if this is possible:
router ospf 100
default-information originate metric 10 metric-type 1 route-map DEFAULT-PREFIX
route-map DEFAULT-CONDITION-RMAP permit 20
match ip address prefix-list DEFAULT-PREFIX
match as-path 33
Can I use bgp attributes to match in a route-map for originating a default route?
thank you,
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Fri, 02/13/2009 - 09:40
Hello Tomasz,
you can try what I did and worked is to check the ip next hop of the BGP default router using
match ip next-hop acl#
that can be a an acceptable check for your needs
Hope to help
Giuseppe
