Warning message
paolo bevilacqua Fri, 02/13/2009 - 10:58
  • Hall of Fame,
    Founding Member
What's the point ? That is like sending 4 packet and an half as fragments, and expect the router to reassemble them, thing that it never does or is expected to do. Only ping to larger MTU and if you're really in an pinging mood, use sweeping sizes.
Mohamad Qayoom Fri, 02/13/2009 - 11:38
  • Bronze, 100 points or more
You can configure MTU size on the interface.
e.g.
mtu 9216
paolo bevilacqua Fri, 02/13/2009 - 11:48
  • Hall of Fame,
    Founding Member
That will fail on numerous types of interface that don't support large MTU, like frame-relay, ethernet, and many others.
cisco24x7 Fri, 02/13/2009 - 12:49
  • Silver, 250 points or more
"That will fail on numerous types of interface that don't support large MTU, like frame-relay, ethernet, and many others."
I like to know where you get this information from. This is a 9000 bytes
ping across a Cisco 7140 router:
[Expert@P1-NGx]# ping -s 9000 -c 5 98.174.21.130
PING 98.174.21.130 (98.174.21.130) 9000(9028) bytes of data.
9008 bytes from 98.174.21.130: icmp_seq=0 ttl=255 time=7.49 ms
9008 bytes from 98.174.21.130: icmp_seq=1 ttl=255 time=7.47 ms
9008 bytes from 98.174.21.130: icmp_seq=2 ttl=255 time=7.52 ms
9008 bytes from 98.174.21.130: icmp_seq=3 ttl=255 time=6.37 ms
9008 bytes from 98.174.21.130: icmp_seq=4 ttl=255 time=6.36 ms
--- 98.174.21.130 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4042ms
rtt min/avg/max/mdev = 6.366/7.045/7.522/0.563 ms, pipe 2
[Expert@P1-NGx]#
paolo bevilacqua Fri, 02/13/2009 - 13:00
  • Hall of Fame,
    Founding Member
I was responding to the suggestion of setting an arbitrary larger MTU on the interface, it is not possible to do so, hence the command fails.
With regard to the ability of the router of reassembling ping packets, your 7140 appears to do that well, other platforms /IOS could not, yet that does not indicate a problem whatsoever.
cisco24x7 Fri, 02/13/2009 - 13:34
It works on the C3640 platforms as well.
The ping goes across the Cisco 3640 and
7140 and it still works:
C3640#ping 98.174.21.134 source f1/0 size 9000 repeat 10
Sending 10, 9000-byte ICMP Echos to 98.174.21.134, timeout is 2 seconds:
Packet sent with a source address of 129.174.1.2
Success rate is 100 percent (10/10), round-trip min/avg/max = 12/14/20 ms
C3640#
Mohamed Sobair Fri, 02/13/2009 - 13:32
  • Gold, 750 points or more
Ping with 8000 byte packet size causes a router to fragments the packets.
The default MTU on Cisco router interface is 1500, The Fragmentation can cause delays, and if the delay is larger than 2 seconds (default time out) you will see . instead of !
This doesnt necessarily means the packet is not transmitted at all, it just means there is no reply within those 2 seconds.
Mohamed
paolo bevilacqua Fri, 02/13/2009 - 13:38
  • Hall of Fame,
    Founding Member
Good point, but to fail due to timeout, the interface must be really, really slow.
More likely the failure is due to some internal buffer that is insufficient.
