UNITY 5 issue
Answered Question
Feb 13th, 2009
  • Bronze, 100 points or more
In a custom call handler if we dial a wrong extension it is automatically routed to the operator...
Is there any way to give another option to the user for entering another number...
Correct Answer by Bradford Magnani about 8 years 5 months ago
Eldho,
In the Tools Depot under Administration Tools, use the Audio Text Manager. Click "Grid View" tab and find the call handler in question. On the right hand side, select the Greetings tab, then Error tab. Here is where you can define where the call goes.
Hope this helps,
Brad
Overall Rating: 5 (1 ratings)
Correct Answer
Bradford Magnani Fri, 02/13/2009 - 11:32
  • Cisco Employee,
Eldho,
Hope this helps,
Brad
