Dial on demand routing between (2) 1841 Routers
matcor9925FDS
I'm trying to set up dial on demand routing between (2) cisco 1841 routers with PPP authentication. Both routers have a modem connected to the AUX port and both modems are connected to a POTS line. I want both routers to be able to initiate a call. Currently the modems are connecting but it appears that I'm failing PPP negotiation. Any help would be greatly appreciated. Below are running configs of both routers.
ROUTER 1 RUNNING CONFIG#
hostname RT108111
enable secret xxx
aaa new-model
aaa authentication ppp default if-needed local
aaa session-id common
chat-script Dialout ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 45 CONNE
CT \c
username ddr password 0 d1@lin
interface FastEthernet0/0
ip address 10.201.30.106 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Async1
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 20
routing dynamic
interface Dialer10
ip address 10.201.30.82 255.255.255.252
encapsulation ppp
dialer pool 20
dialer remote-name asyncTESTserver
dialer idle-timeout 900
dialer string 2077
dialer-group 1
ppp authentication chap
router eigrp 65201
network 10.201.30.104 0.0.0.3
auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer10
access-list 101 remark define dialer traffic
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
dialer-list 2 protocol ip permit
line aux 0
exec-timeout 0 0
script dialer Dialout
modem InOut
modem autoconfigure type default
transport input all
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
ROUTER 2 RUNNING CONFIG#
hostname asyncTESTserver
enable secret xxx/
aaa new-model
memory-size iomem 5
dot11 syslog
ip cef
CT \c
username xxx password xxx
ip address 10.201.30.105 255.255.255.252
duplex auto
speed auto
ip address 10.201.30.86 255.255.255.252
duplex auto
speed auto
interface Async1
no ip address
encapsulation ppp
dialer in-band
routing dynamic
interface Dialer10
ip address 10.201.30.81 255.255.255.252
encapsulation ppp
dialer pool 20
dialer remote-name RT108111
dialer-group 1
ppp authentication chap callout
router eigrp 65201
network 10.201.30.80 0.0.0.3
network 10.201.30.84 0.0.0.3
auto-summary
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 10.201.30.80 255.255.255.252 Dialer10
ip route 10.201.40.0 255.255.255.0 Dialer10
access-list 101 permit ip any 10.201.40.0 0.0.0.255
line aux 0
exec-timeout 0 0
modem InOut
transport input all
stopbits 1
speed 115200
line vty 0 4
paolo bevilacqua
The async interfaces needs IP addresses or ip unnumbered, to begin with.
If still trouble, send output of debug ppp negotiation.
