Cisco SB SPA9000 SPA400
Overall Rating: 3 (1 ratings)
paolo bevilacqua Fri, 02/13/2009 - 12:27
  • Hall of Fame,
    Founding Member
It is quite easy and functional, but not comparable in any way to true Cisco solutions. You need the SPA900 and phones only. SPA400 is an FXO gateway, optional.
There are documents and guides, if your reseller cannot help if providing these, come back here.
Paolo,
I'm trying to setup phones between 2 houses that have broadband internet connections...i would like to have the 1 POTS phone line in one of the houses.
if I have vpn between the houses (I assume I need different routers or fw's to do that) should one of the houses having an SPA400 be sufficient...
also to make sure...even without a phone line or any service other than internet...i shd be able to use this as an internal phone system between the houses...
:JoeL
paolo bevilacqua Fri, 02/13/2009 - 12:42
  • Hall of Fame,
    Founding Member
Yes to all questions. The "little PBX" is the SPA9000, 400 is an FXO GW.
paolo bevilacqua Fri, 02/13/2009 - 14:26
  • Hall of Fame,
    Founding Member
You don't necessarily need the SPA9000, the linksys phones can be configured to be standalone and hotlined to each other.
I think that is also compatible with each one getting independent service from an ITSP.
I also know understand that linksys makes VPN-capable cable routers, if you're allowed by the ISP to have your own. So not too many devices really.
