Time out feature on CCM 6.1?
Feb 13th, 2009
Is there a way to change the time out feature in Communication Manager so that I don't get kicked out after 5 minuates? Is this setting on the server (Tomcat service?) and how can I change it?
Regards, Chet
Jaime Valencia Fri, 02/13/2009 - 14:08
i assume we're talking about the session timeout in CCMAdmin, if that's the case it's not configurable.
there's an enhancement request for this
java
if this helps, please rate
red73mustang Tue, 02/17/2009 - 13:15
This answeres my question, but it does not really "help"(not your fault). How do I rate your answer?
Jaime Valencia Tue, 02/17/2009 - 14:13
that's one of the times when all you can say is: Don't shoot the messenger =)
There have been several times when i have provided the answer and it was not something the one asking wanted to hear but i mean, i work with what i got, i don't create the systems i simply provide info on how they work. those times they rated me 1!!
i appreciate you understanding that i only provide the info and not giving me a bad rating, simply leave it like that. no rating.
java
steakandeggs Tue, 04/21/2009 - 11:48
As always with Cisco and GUIs, yer on your own.
I use Firefox with the Reloadevery add-on. In combination with AutoHotKey all you have to do when you load the callmanager page is press ctrl-r (or whatever you set up) and the CUCM pbage will refresh every X minutes. This will keep it from autologging out. I know, it's a disgusting workaround but hey there you go.
I bet you could script the bookmark so that is loads with Reloadevery already activated... Or Cisco could just fix their problem.
red73mustang Tue, 04/21/2009 - 14:33
Thanks steakandeggs, I normally use I.E., but I will give Firefox with the add in a try. Kind of reminds me of the old "Dial up" ISP days that would kick you off if it sensed you were inactive. They had apps for that too!!!!
