Authentication Error
Answered Question
Feb 13th, 2009
  • Bronze, 100 points or more
I am currently upgraded my 871W to AdvanceIPServices 12.4(22)T IOS which was done to fix a bug with not broadcasting my SSID.
Since then I have been having authentication issues. I am using WPA with PSK. My PC and the rest of the network devices can connect to the wireless router initially, but if the connection is terminated for whatever reason and I attempt to reconnect a device I receive an authentication error.
Attached is my current configuration. Any help would be appreciated
Correct Answer by Stephen Rodriguez about 8 years 2 months ago
Couple of questions, are you using the 87x as a bridge? do you have reallllllly old devices in your network? If not:
dot11 ssid cisco
vlan 1 <---not needed
authentication open
authentication shared <---not needed
authentication key-management wpa
guest-mode
infrastructure-ssid <---not needed
From the config, you don't need to have the VLAN statement in the SSID, and you don't need the sub-interface under the radio. Just put the main interface in bridge-group 1.
HTH,
Steve
Overall Rating: 5 (1 ratings)
Correct Answer
Stephen Rodriguez Sun, 02/15/2009 - 16:08
  • Purple, 4500 points or more
dot11 ssid cisco
authentication open
guest-mode
HTH,
Steve
gojericho0 Wed, 02/18/2009 - 15:42
Steve not sure why, but when i took the authentication shared command out it started working properly.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
