E1 R2 Digital
Feb 13th, 2009
I have customer in Sao Paulo, Brazil.2801 gw SRST site(CCM 4.1.3). Firstly I search for 2 days to get hold of a RJ45 to BNC, 75 Ohm, Unbalanced cable. I got the part eventually from a Cisco shop. This connects to a VWIC2-2MFT-T1/E1. Something I saw in my configs is a show controller E1 says balanced:
OSANET01# sh controller e1
E1 0/2/0 is up.
Applique type is Channelized E1 - balance
controller E1 0/2/0
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled ani
ds0-group 1 timeslots 17-31 type r2-digital r2-compelled ani
cas-custom 0
country brazil use-defaults
metering
category 2
answer-signal group-b 1
cas-custom 1
metering
category 2
description link to TELCO
voice-port 0/2/0:0
no vad
cptone BR
voice-port 0/2/0:1
no vad
cptone BR
dial-peer voice 1 pots
translation-profile incoming 5digits
destination-pattern .T
progress_ind alert enable 8
incoming called-number .T
direct-inward-dial
port 0/2/0:0
forward-digits all
dial-peer voice 2 pots
direct-inward-dial
port 0/2/0:1
forward-digits all
dial-peer voice 20 voip
destination-pattern 30...
session target ipv4: X.X.X.X
codec g711ulaw
no vad
When dialling in I get the following on my debug:
Feb 13 19:07:26.135 BRT: //47/1DE6B814804D/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x654666D4, Call Id=47
Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Feb 13 19:07:26.139 BRT: //48/1DE6B814804D/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Feb 13 19:07:26.139 BRT: //48/1DE6B814804D/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
And when dialling out, the phone ring once, and then goes engaged:
Feb 13 19:08:17.803 BRT: //49/004291911100/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x64DA4504, Call Id=49
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
Feb 13 19:08:17.803 BRT: //49/004291911100/CCAPI/cc_api_get_transfer_info:
Feb 13 19:08:17.803 BRT: //49/004291911100/CCAPI/ccConferenceDestroy:
Conference Id=0x6, Tag=0x0
Feb 13 19:08:17.803 BRT: //49/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x6, Source Interface=0x64DA4504, Source Call Id=49,
csim start works
Nicholas Matthews Fri, 02/13/2009 - 16:15
  • Red, 2250 points or more
On dialing in:
The E1 R2 side of the circuit is disconnecting with a normal cause code. Hard to say without looking at painful E1 R2 debugs.
On dialing out:
Your H323 leg is disconnecting with no resources. Check DSP resources, transcoding, and codecs.
Good luck,
-nick
LouisKoekemoer_2 Fri, 02/13/2009 - 16:23
I just noticed a possible mistake. I see I have 2 ds0 groups. I have debug voip ccapi's which I could look through if I just knew what to look for. As you say it is just quit bulky. Could send it to you if I had your mail address:) DSP's? I have a PVDM 2-64, and a PVDM 2-32 in there. Can see what that should be an issue. I have 8 transcoding, 6 conferencing, and 250 software sessions sucessfully configured. Somethat bothers me is the fact that the cable is unbalanced, and that when I do a show controller E1, it say balanced. Could this be an issue.
Nicholas Matthews Fri, 02/13/2009 - 16:29
There's not really a 'good' spot to look. You have to know the E1 R2 signaling in order to find out who's creating the disconnect condition - which isn't any fun because there are a TON of E1 R2 variations.
debug vpm signal is the one that's going show you the state changes on the E1 R2 circuit. I don't see these circuit very often at all, so it's hard to tell you.
-nick
paolo bevilacqua Sun, 02/15/2009 - 10:00
  • Hall of Fame,
    Founding Member
True, but the good news is that in most cases, the circuits are digital/compelled, and tolerant of minor mistakes in customization. If you're interested in a couple of non-cisco docs detailing R2, let me know and I'll send these to you.
paolo bevilacqua Sun, 02/15/2009 - 11:15
  • Hall of Fame,
    Founding Member
I would try 12.4(3j).
I've sent you the docs, I hope you will never need them.
paolo bevilacqua Sat, 02/14/2009 - 03:49
  • Hall of Fame,
    Founding Member
Ola', for unbalanced E1 configure
controller E1 x/y
line-termination 75-ohm
Also remember to configure network-clock-participate and network-clock-select to give priority to this E1.
I don't think this is the cause of the problem however.
lagos Sun, 02/15/2009 - 05:49
  • Cisco Employee,
Is your carrier Telefonica in Sao Paulo?
I would suggest using just one ds0/CAS group:
ds0-group 1 timeslots 1-15,17-31 type r2-...
I would also suggest adding this to your voice-port:
bearer-cap Speech
Good luck.
paolo bevilacqua Sun, 02/15/2009 - 08:22
  • Hall of Fame,
    Founding Member
lagos, very often E1 R2 circuits are split in two sets of channels, to ensure that outgoing and incoming calls never overlap, minimizing the possibility of glare.
Also, bearer-capability is effective on PRI circuits only. There is no bearer capability concept in E1 R2.
