timers spanning-tree portfast CAT vs IOS
Answered Question
Feb 13th, 2009
hi, hello i need down the timers of CAT spanning-tre portfast very small possible as IOS?
how can i do?
thanks
Correct Answer by glen.grant about 8 years 5 months ago
To speed it up a little use the "set port host" command which turns on portfast and turns off etherchannel and trunking which will maybe save a second or 2 also .
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Sat, 02/14/2009 - 01:29
  • Hall of Fame,
    Founding Member
Hello Uzziel,
to enable STP portfast on CatOS you can use
set spantree portfast mod/num
if you do so it should be fine to support PCs or servers that need to boot on LAN.
Hope to help
Giuseppe
Correct Answer
glen.grant Sat, 02/14/2009 - 04:34
  • Purple, 4500 points or more
