Frame Relay Voice Adaptive Shaping
Feb 13th, 2009
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
In the 12.4 mainline documentation, the configuration example includes the command in the serial interface:
frame-relay fragmentation voice-adaptive deactivation 50
and this command in the policy map attached to the frame-relay map-class:
shape fr-voice-adapt deactivation 50
Both commands have exactly the same description as to their function. Are both required? It's really not clear.
Any help appreciated.
Overall Rating: 5 (1 ratings)
Edison Ortiz Sat, 02/14/2009 - 11:30
  • Hall of Fame,
    Founding Member
Are both required?
No.
When configuring shaping or any QoS features in Frame-Relay, you have 2 choices:
1) You can configure a map-class frame-relay for per PVC QoS services
or
2) You can configure MQC which is the class-map and policy-map combination. This option applied to an interface will affect all PVCs in the interface.
Now, you can also use MQC and apply the service policy to a map-class. If you configure QoS features in the MQC that are similar to the ones from the map-class - like the example above - you don't need to repeat the same.
HTH,
__
Edison.
