Istvan_Rabai Sat, 02/14/2009 - 11:11
  • Gold, 750 points or more
Hi Just,
I think you are mixing concepts here.
The inside local address is the private ip address of a host inside your network.
The outside global address is the public ip address of a target host on the outside network, e.g. on the Internet.
I suppose you wanted to translate the inside local address to an inside global address.
The inside global address is a public ip address that your company was assigned to use on the Internet.
For translation from inside local to inside global you can use the ip address of the interface on which you configured "ip nat outside", or you can use a different public ip address.
The key is that your ISP must be able to route packets to that public ip address (to your inside global address).
Cheers:
Istvan
Just Kennie Sun, 02/15/2009 - 22:13
I understand, please my question is must I assign one of the inside global to an (outside)interface before it works.
dinesh.das Sun, 02/15/2009 - 22:31
The interface, which you are connecting to the global Network, should be configured with the Global IP address (outside)and private IP should be NAT through this device only.
You know better about your network connectivity
paolo bevilacqua Mon, 02/16/2009 - 02:50
  • Hall of Fame,
    Founding Member
No, not necessarily.
dinesh.das Mon, 02/16/2009 - 04:53
Hi Bevilacqua,
No for interface IP or NAT (or BOTH)
If you do not mind, please throw some light how it will work? (Connecting to global network with private IP) is I missing out any thing!
paolo bevilacqua Mon, 02/16/2009 - 05:01
  • Hall of Fame,
    Founding Member
I do not understand your question. If it is unrelated to the question here, open a new thread and explain.
