ASA 5505, Read-only filesystem
Answered Question
Feb 14th, 2009
Hi!
I was doing a change in m ASA5505 today, but when I was trying to save it to memory, I got the message
"Building configuration...
Cryptochecksum: xxxxxxxxxxx
%Error opening disk0:/.private/startup-config (Read-only file system)
Error executing command
[FAILED]"
What can I do to resolve this? I have tried reloading the ASA, but that did not help. I can not do changes to the filesystem (copy, delete) either.
Correct Answer by Syed Iftekhar Ahmed about 8 years 4 months ago
Try
ASA-5505(config)# fsck disk0:
It looks as if flash memory is corrupted. Command mentioned above does a file system check and attempts to fix corruptions.
Syed
Overall Rating: 5 (2 ratings)
Correct Answer
Syed Iftekhar Ahmed Sat, 02/14/2009 - 12:14
  • Blue, 1500 points or more
Try
Syed
mniklasson Sat, 02/14/2009 - 13:04
Thanks, that fixed the problem. fsck did not output anything, but after running it, it works.
