weird routing
Answered Question
Feb 14th, 2009
i have a client with a 2801 router in a net cafe with 1 leased line and 2 DSLs 24
and he wants the games trafic to be routed through leased line(WIC-1T) MSNs Internet through 1st DSL and P2P trafic through 2nd DSL. Is this possible assuming the customer has all the interfaces needed and if yes a TIP to do it would be great.
Correct Answer by Giuseppe Larosa about 8 years 3 months ago
Hello Emmanuel,
you can use policy based routing to forward traffic based on criteria beyond destination routing.
With PBR you use a route-map to decide how to send traffic:
You need to find out what TCP and UDP ports are used by the different applications.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/20ew/configuration/guide/pbroute.html
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Sat, 02/14/2009 - 02:26
  • Hall of Fame,
    Founding Member
Hello Emmanuel,
see
Hope to help
Giuseppe
