Switch console
Feb 14th, 2009
Dear all,
I am facing Problem with C2960 Switch that I could not able to take console to it. And also I given default COM Port Settings.
royalblues Sat, 02/14/2009 - 12:29
Are you able to see any characters while the switch is booting when connected to console?
It is possible that somebody might have chnaged the default console speed. The baud rate you choose must correctly match with the console settings
msasikumar Sat, 02/14/2009 - 21:52
We have changed the Values then also we could not get the console
Leo Laohoo Sun, 02/15/2009 - 15:16
How about the client/laptop you are using? Make sure the Hyperterminal settings are set correctly.
msasikumar Sun, 02/15/2009 - 22:53
we using Laptop(Xp)and we had setted correctly once we enetered in Concole it's getting hang and if we go to ROM Mode there also switch getting hang
