02-14-2009 03:53 AM - edited 03-06-2019 04:02 AM
I want to configure private vlan on l3 cisco 3750 switch.
Can any one tell me the config,Pls find the attachment.
02-14-2009 04:18 AM
Hello Arjun,
after seen your picture I would take a different approach using VRF lite if the target is to avoid the two service providers CE nodes to talk to each other.
here are the links to private vlan config for c3750
see the section private vlans and SVIs
I see in 12.2(44)SE for C3750 no chapter for VRF lite.
Hope to help
Giuseppe
02-14-2009 04:40 AM
Dear...
Thanx a lot..!
02-16-2009 02:51 AM
Hi......
I want to my two ISP should not communicate to firewall port.
Is it possible?
If yes what could be the config?
Thanx.
02-16-2009 06:56 AM
Hello Arjun,
I'm not sure that I've understood correctly.
if the switch is acting as L3 switch you can simply configure an ACL on the SVI towards the FW to deny direct communication.
Hope to help
Giuseppe
