Changing CLID of PRI
Feb 14th, 2009
Is it possible to change the Caller Line ID of an Individual PRI connected to AS5400 VG in the IPCC Enterprise Environment.
gm3gmgm3gm Sat, 02/14/2009 - 11:16
Hi Bevilacqua,
I am able to make it by setting the External phone number mask in the IP Phone and checking the calling party external phone number in route pattern.
Could you please brief me how i can acheive this in the AS5400 VG.
Anonymous (not verified) Sat, 02/14/2009 - 11:30
Hey I could use an example of your inbound dial-peer config on that (if you have DID's"
I am working on getting inbound calling set up and its just not happening.
Cause i = 0x8081 - Unallocated/unassigned number
Paolo Bevilacqua Sat, 02/14/2009 - 11:35
first of all check on the VG which number is sent with "debug isdn q931" and "term mon".
gm3gmgm3gm Sat, 02/14/2009 - 12:35
In my case i would like to know how to change the outgoing calling party number.we have 2 pri under a trunk group associated to Route pattern 9.8!#
Currently,debug q931 shows only the 5 digit Directory number of IP phone. I want to change 5 digit DN to CLID.
Route patern 9.8! & 9.8!# with predot Trailing -#.
VG Configuration
voice translation-rule 4
rule 1 /^8/ //
voice translation-profile XXXX_Outgoing
translate called 4
dial-peer voice 53 pots
trunkgroup XXXX_Out
translation-profile outgoing XXXX_outgoing
destination-pattern 8T
no digit-strip
forward-digits all
Paolo Bevilacqua Sat, 02/14/2009 - 12:48
You have to ask your telco how many digits to send. Usually that is the same as DID digits received.
Unrelated, you can remove the voice translation-profile, rule, "no digit-strip" and "forward-digits all". It is not necessary because a pots DP already strips matched digits in destination-pattern.
gm3gmgm3gm Mon, 02/16/2009 - 11:51
clid command under dial-peer voice enabled me to change the network calling number.
