Meeting Place ....
Feb 14th, 2009
hi guys ,
I have to configure Meeting Place Express V2.0 .. this would be my first installation .. can any tell me on which IOS it will work .. can i configure it on my desktop at windows server like we can use Cisco Unity or we can run CCM 6.0 at VMWare at home .. is there any possibilty for meetig place express 2.0
mesumbeslin Sat, 02/14/2009 - 23:08
What do you mean by "which IOS it will work"? MPEv2.0 is software only and installed on MCS servers.It is not IOS based.
It supports desktop integration if that is what you mean by "configure it on my desktop"
I don't understand the rest of the questions,can you be more explicit?
Ahmed Nasry Abd... Sun, 02/15/2009 - 04:45
i mean to ask that on which OS Meeting Place runs .. like cisco unity 5.x is windows based .. we can configure it on Win2000 Server machine ok same like that Cisco Call Manager 6.0 is linux based so we can configure it on VMWare at home and can do practice .... about Meeting Place on which OS it runs there any solution to configure it on laptops or desktop !!!!!
mesumbeslin Sun, 02/15/2009 - 09:25
Ok...The OS is Linux-based and it is included within the software,you don't install it separately just like CUCM7.
I believe if you can install CUCM on vmware,you should be able to install UMPE too,though I haven't tried it before.
Hope this helps,
Ahmed Nasry Abd... Mon, 02/16/2009 - 10:56
Yes, that what i was looking for !!! well thank tomslin .. have you worked on Meeting Place Express V2.0 ???
