ccm-manager Configuration Auto-Download failed
Answered Question
Feb 14th, 2009
I recently add a remote site. The Gateway is running IOS 12.4.15-T8 and the Callmanager is V5.12. Everthing seems to be working however I notice the Vocie Gateway indicate the Configuration Auto-Download Fail. See below.
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
Download Attempted : 5
Download Successful : 0
Download Failed : 0
TFTP Download Failed : 8857
Configuration Attempted : 0
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
I have attached a ccm debug and ccm config.
Any help is appreciated.
Mark
Correct Answer by Nicholas Matthews about 8 years 2 months ago
You may want to try a 'no ccm mgcp' 'ccm mgcp'.
-nick
Overall Rating: 5 (1 ratings)
Nicholas Matthews Tue, 02/17/2009 - 18:53
  • Red, 2250 points or more
Hi Mark,
I would do a quick test:
Try downloading this file:
tftp://10.108.15.9/CATOR3RT2851-1.cnf.xml
You can use the tftp client that should be built into windows (maybe not Vista), a 3rd party tftp client, or just the router cli.
If you can download it, it may be a ccm manager config error, or a way the CUCM is writing the file.
If you can't download it, I would try restarting the TFTP service on CUCM.
-nick
markcarat Tue, 02/17/2009 - 19:40
Hi Nick,
I am able to download the file using tftp client or from a PC's commnd prompt. But I can't run the tftp command from touter's cli, % Unrecognized command. Any suggestions?
Mark
Correct Answer
Nicholas Matthews Tue, 02/17/2009 - 19:43
-nick
markcarat Tue, 02/17/2009 - 20:10
Thanks Nick. The no ccm mgcp and ccm mgcp has resolved the problem.
Thanks again
