Maintaining list of allowed vlans on etherchannel
Answered Question
Feb 14th, 2009
Looks like a typical trivial task, but I still can't find solution in docs.
At the beginning, I had just one link to uplink switch, then added the second one and built etherchannel. I do not undrestand how to modify list of allowed vlans so that to avoid errors. Should i have "switchport" commands on Port-Channel level or Gigabit ethernet level? Where should I apply "spanning-tree" commands?
interface Port-channel1
switchport
switchport trunk allowed vlan 1,6,21
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet3/1
description link1
switchport
channel-group 1 mode on
interface GigabitEthernet4/1
description link2
switchport
Thank you in advance!
Correct Answer by adamclarkuk_2 about 8 years 3 months ago
You need to apply any configuration changes to your Port-Channel interface, this will update the config on all members within that port channel.
Applying config to a single physical interface could cause it to drop out of the etherchannel.
Hope that helps.
Overall Rating: 4.3 (4 ratings)
Correct Answer
adamclarkuk_2 Sat, 02/14/2009 - 06:48
  • Silver, 250 points or more
Hope that helps.
glen.grant Sat, 02/14/2009 - 09:00
  • Purple, 4500 points or more
It goes on the " interface port channel" . To add vlans use "switchport trunk allowed vlan add " .
Giuseppe Larosa Sat, 02/14/2009 - 12:23
  • Hall of Fame,
    Founding Member
Hello Mihails,
once the etherchannel is up and running do changes only on the port-channel interface.
We had very bad experiences two times for someone trying to add a vlan on a member link: both times a bridging loop formed with extended out of service
The involved devices were C6500 with Sup 720 3B.
So I strongly recommend once the etherchannel is up to makes changes only on the port-channel interface
use the command suggested by Glen:
switchport trunk allowed vlan add x
Hope to help
Giuseppe
