ssl vpn issue
anitachoi3
If I change the ip address of SSL VPN box, do I re-generate the cert for the new IP address of SSL VPN box?
rdgs
Ivan Martinon
Level 7
Level 7
It depends on whether your cert was enrolled using ip address or FQDN, if ip address was used then yes you need to regenerate, if it was via FQDN and this FQDN has not changed no need of it.
Ivan Martinon
Level 7
Level 7
