Problem When Upgrade Router Rommon Mode From USB
mibrahim81
Dear All,
While i was trying to upgrade the Rommon IOS via USB, I found the below error message.
Kindly advise
cisco#upgrade rom-monitor file usbflash0:
%Error: srec file read failed
BR
Mohamed Ibrahim
6 Replies 6
paolo bevilacqua
You have to specify the filename also, you are not doing so in the example above.
Dear p.bevilacqua ,
Thanks for interset
But i specified the file name as shown with the same error message
Abba_Test#upgrade rom-monitor file usbflash0:C2800NM_RM2.srec.124-13r.T
BR,
Mohamed Ibrahim
Correct filename should be C2800NM_RM2.srec.124-13r.T6
Check that you file is not corrupt and try again.
Dear p.bevilacqua ,
I downloaded this IOS from CISCO Web site and it is C2800NM_RM2.srec.124-13r.T NOT C2800NM_RM2.srec.124-13r.T6
Is there is special USB flash type dedicated for that ?
BR
Mohamed Ibrahim
I've verified this right now and indeed T6 is the correct filename, so check again.
You can verify that your usb stick works Ok by copying some files from/to regular flash for a test.
If still trouble, use TFTP that works all the times.
Nope. I upgraded my routers (1800/2800/3800) ROMmon using USB and it worked. What is the specific model of the router? Is it a 2811 or a 2821/2841?
