WAV Requirements for IVR voice prompts
Answered Question
Feb 15th, 2009
Could somebody give me technical Requirements for IVR WAV voice prompts?
Correct Answer by Rob Huffman about 8 years 4 months ago
Hi Alexander,
Save each prompt as a .wav file in CCITT (mu-law) 8-kHz, 8-bit, mono format
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/installation/guide/uccx70gsipivr.pdf
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Sun, 02/15/2009 - 07:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alexander,
Hope this helps!
Rob
Chris Deren Sun, 02/15/2009 - 08:26
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
Just to add, this depends on what codec your IPIVR was installed with as it can be either G711 or G729, you will need to ensure that your wav files are in that codec, for G711 it's simply PCM encoding.
HTH,
Chris
