SUP720 In CAT6509-E running CatOS - replacement of failed SUP
Feb 15th, 2009
Say a CAT 6509-E has SUP720 in slots 5 and 6 and say SUP720 in slot 5 has failed and 6 has become active.
Now, I wish to replace the SUP720 in slot 5 now, but I cannot tell whether the RMA I received has CatOS or IOS.
I do not have another switch in the lab to do the conversion and none of the SUP720 has Compact Flash.
If I replace the SUP720 in slot 5 with the RMA I received, will the CatOS from Slot 6 get copied to the SUP720 in 5 and that will also start running CaTOS or shouldn't I take that risk?
What about config?
Edison Ortiz Sun, 02/15/2009 - 08:57
  • Hall of Fame,
    Founding Member
What about config?
No, There isn't an IOS synchronization process between Supervisors. When upgrading the IOS on one Supervisor, you must also manually upgrade the IOS on the secondary Supervisor.
The Supervisors synchronize the startup config only when the IOS running on both Supervisors are compatible.
Therefore, to answer your question, whatever Supervisor becomes the active Supervisor during the Switch boot will dictate the IOS version and config that device will run.
HTH,
__
Edison.
Leo Laohoo Sun, 02/15/2009 - 15:24
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Had this issue last year when I RMA-ed a Sup32. I had to specify to Cisco TAC that the replacement card must have IOS loaded (previous RMA arrived with CatOS).
And the card arrived with monolithic (non-modular) IOS.
Edison Ortiz Sun, 02/15/2009 - 16:29
  • Hall of Fame,
    Founding Member
Sorry to hear that inconvenience but I hope my reply made sense on how the synchronization takes place.
__
Edison.
Leo Laohoo Sun, 02/15/2009 - 15:28
  • Hall of Fame,
    2017 LAN, Wireless
System Software Conversion from CatOS to Cisco IOS for Catalyst 6500/6000 Switches
www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml#conv_720
astanislaus Sun, 02/15/2009 - 15:34
I know how to convert from CatOS to IOS and vice versa on SUP720, but I need a spare chassis in lab, which I don't have at the moment. This customer will not allow me to take his CORE switch down for 1 or more hours and use his switch to convert the RMA module if it comes with IOS. HE is running CatOS.
Leo Laohoo Sun, 02/15/2009 - 16:09
  • Hall of Fame,
    2017 LAN, Wireless
That leaves you with 2 options:
1. Upgrade/downgrade the IOS on the same chassis the Sup720. This can be done but as to whether it will affect the operation of the entire chassis, I am not sure.
2. RMA the card again and have them ship you the card with the IOS you want.
Hope this helps.
