02-15-2009 12:18 PM - edited 03-15-2019 04:14 PM
When we want to choose the signaling at the T1 CAS we find that:
Router(config-controller)#ds0-group ds0-group-number timeslots
timeslot-list [service service-type] type {e&m-fgb | e&m-fgd | e&mimmediate-
start | fgd-eana | fgd-os | fxs-ground-start | fxs-loop-start
| none | r1-itu | r1-modified | r1-turkey}
My question here is : what is the meaning of fxs-loop-start and fxs-ground-start and fxo-loop-start and fxo-ground-start ?
Thanks....
02-15-2009 12:23 PM
02-15-2009 12:30 PM
is this mean that each channel at T1 will act as fxo or fxs with analog signaling ground start and loop start?
02-15-2009 12:34 PM
Yes. The A/B bits mimics hook status and ring current.
02-15-2009 01:53 PM
But there is a problem that fxo don't support DID also the fxs ( fxs must be FXS DID)?
What is the solution?
02-15-2009 02:14 PM
To use e&m for did, pri for did and ani.
