E1 PRI with CallManger
Feb 15th, 2009
I Have a callmananager ver 6 with Voice h323 Bateway and E1 PRI interface
When Phone from Callmanager call the outside called number doest hear anything
But with the Phone form CallManger Express ist working fine fro the same Gateway
Afragoso2009 Sun, 02/15/2009 - 16:16
IN my situation the ring its OK ,
The problem is ;
I can hear the other side , bu the other side cant hear me
Paolo Bevilacqua Mon, 02/16/2009 - 03:27
Have you followed the steps in the document mentioned above? Your specific case is detailed there.
Afragoso2009 Mon, 02/16/2009 - 08:29
The document above it was not my situation.
Any way thaks a lot for your feedback
But I had already solve the problem
Its was a routing problem , I meas the VOice Gateway couldn ping to the IP Phone
I solve this routing problem and its working fine now
Best Regards to all
