^^^ Question about DNIS and ANI?
Feb 15th, 2009
Which voice port can send and receive DNIS and ANI from the following:
1- Analog voice port:
2- Digital voice port:
T1 CAS , E1 R2 CAS , T1/E1 PRI , BRI
Paolo Bevilacqua Sun, 02/15/2009 - 14:07
Hi, since you have been studying this stuff for a while, why don't you try answering that yourself as an exercise?
If is not difficult once you understand the basics on each type.
titomontos Sun, 02/15/2009 - 14:14
it isn't a quiz :),
i have just misunderstanding so i need the answer to be ensure.
Paolo Bevilacqua Sun, 02/15/2009 - 14:15
If it is not a quiz, what problem are you trying to solve? Seems to me you're studying for certification.
Paolo Bevilacqua Sun, 02/15/2009 - 14:22
I think you should focus on your training material, and reason on it.
It is not that you can resort to this forum for any doubt, you've had many already.
titomontos Sun, 02/15/2009 - 14:37
I think cisco make this forum for all.
I will answer and you can tell me the true or false, deal?
AT analog the FXO: send only DNIS to PSTN and canot receive it
e&m: send and receive DNIS/ANI
FXS: i canot find any data about this
AT digital: E1 R2 CAS can send and receive both also the pri
T1 CAS E&M give more choice but if we use any signaling expect E&M i canot get any data about it.
So plz tell me.
Paolo Bevilacqua Sun, 02/15/2009 - 15:02
Yes the forum is for everyone, but the other students pass the test without asking here, so why you should be different ?
However, FXS it's the other side of FXO, so think about it. Also think caller ID.
E&M: there is no defined universal standard for sending ANI.
PRI and BRI have DNIS/ANI natively.
titomontos Sun, 02/15/2009 - 15:23
1st issue : it is a wrong thinking if we confine VOIP technology as a test and result, we are engineers so we must understand this technology before we thinking in test, so i try to get the right informations.
2nd issue : Thanks for help.
