Equipment
Feb 15th, 2009
Hello
I am going for my CCNA. I have a 3600 router and 2900XL switch. Is there anything other equipment I need?
Overall Rating: 5 (1 ratings)
Justin Brenton Sun, 02/15/2009 - 16:50
Hi ehjordan5,
You should be fine as you have L2 and L3 covered.
You can also use an IOS emulator on your pc if you need to do anything else. www.gns3.net
Hope this helps, please rate if so
Justin
tperrier Mon, 02/16/2009 - 01:07
I'd trade the 2900XL (really old now) for a 2950, which is quite cheap nowadays (used).
