02-15-2009 08:27 PM
Hi Experts,
Just like to confirm this doubt. Does CiscoWorks LMS 3.0 RME 4.1.1 Config Archive Mgmt supporting WLC, IPS, ASA and routers?
Yi Shyuan
Solved! Go to Solution.
02-15-2009 11:18 PM
Yes, the 2821 is also supported by RME 4.1.1. The complete device lists can be found at:
02-15-2009 09:14 PM
If you have installed all of the available RME and Common Services device updates (under Common Services > Software Center > Device Updates), then RME supports WLC and ASA devices. It does not support the IPS.
02-15-2009 11:10 PM
Hi Joe,
How about router Cisco 2821? Thanks
02-15-2009 11:18 PM
