02-15-2009 10:23 PM - edited 03-04-2019 03:34 AM
Hi Experts,
I m doing policy-based static NAT with the following scenario.
R6----|
|---R4----------Serial---------R5
| -------- FR -----------
R1----|
R1,R4,R6 are on common Ethernet of subnet - 10.0.0.0/24 . R4 to R5 on serial link subnet is 155.1.45.0/24 and on FR link subnet is 155.1.0.0/24.
Other than this on R5, I have configured two loopbacks as loop 0 - 150.1.5.5/24 and loop 1 - 150.1.55.55/24.
I have configured OSPF between R4 & R5 for routing. R1 & R6 have default routes pointing to R4. So entire routing is complete.
Now, I have configured R4 as below,
ip nat inside source static 10.0.0.1 150.1.4.1 route-map NATLOOP0
ip nat inside source static 10.0.0.1 150.1.4.2 route-map NATLOOP1
ip nat inside source static 10.0.0.6 150.1.4.3 route-map NATLOOP0
ip nat inside source static 10.0.0.6 150.1.4.5 route-map NATLOOP1
ip access-list extended LOOPBACK0
permit ip 10.0.0.0 0.0.0.255 150.1.5.5 0.0.0.0
ip access-list extended LOOPBACK1
permit ip 10.0.0.0 0.0.0.255 150.1.55.55 0.0.0.0
route-map NATLOOP0 permit 10
match ip address LOOPBACK0
set ip next-hop 155.1.0.5
route-map NATLOOP1 permit 10
match ip address LOOPBACK1
set ip next-hop 155.1.45.5
So, In this case my NAT is not working as desired. I want to configure like this when I go frm R1 to loop 0 (150.1.5.5) of R5 traffic shl go to FR interface (155.1.0.5) and when I go frm R1 to Loop 1 of R5 (150.1.55.55) traffic shld go via serial interface (that is 155.1.45.5) with NAT translation.
But this is not working as per the requirement.
02-16-2009 12:06 AM
Hello Mazhar,
just a basic check:
have you configured
ip nat inside under R4 lan interface
and
ip nat outside out the relevant interfaces
without these commands NAT action is not triggered
Hope to help
Giuseppe
02-16-2009 02:14 AM
try the following as well this is for one router applly the other to other router
ip nat pool t0-l0 150.1.4.1 150.1.4.1
route map map1
match ip add LOOBACK0
match interface [outgoing interface]
ip nat inside source route-map map1 pool t0-l0
now this will do the nating based one ACL and outgoing interface
with NATing u can not use set next hop becuase it is not a policy route
to force ur router to send spicific traffic out thorugh a spicified interface u need to use a policy routing with a route map
apply it to the internal interface
this way ur traffic will be policy routed first then wil be nated
good luck
if helpful Rate
02-16-2009 09:09 PM
Hi marwanshawi ,
hey this is informative, will try to do in this way but still Doc CD has used set nxt hop under NAT.
Thanks.
