royalblues Sun, 02/15/2009 - 23:36
  • Green, 3000 points or more
USe the break sequence cntl+shft+6 (all together) then x
Narayan
bagvanliju Sun, 02/15/2009 - 23:40
Hi Narayan,
Even i have experianced the same.if continous ping has given it had stopped with --->cntl+shft+6 (all together) then x ,
but in the case of traceroute .....many times we have to wait till the 30th hop
ujil
royalblues Sun, 02/15/2009 - 23:46
For me it works always.. Actually you dont even need to press x after the combined sequence
MS_IP_L3#traceroute 7.2.2.2
Tracing the route to 7.2.2.2
1 *
MS_IP_L3#
Narayan
cyptic Mon, 02/16/2009 - 00:24
Hi!
This is the strange way of doing it.
hold: ctrl+shift+6
release and press x.
milan.kulik Mon, 02/16/2009 - 01:04
  • Red, 2250 points or more
x is not necessary, sometimes even not good to use (while connected to from one router another router via a Telnet session and running traceroute there, it would just return to the first router session).
But ctrl+shift+6
pressed several times might help.
BR,
Milan
Richard Burts Mon, 02/16/2009 - 07:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
In my experience the X is not needed and as Milan points out is sometimes disruptive. I find that frequently I must repeat the key stroke sequence several times to stop a traceroute, but I find that the keystroke sequence of CTRL + shift + 6 is effective in stopping traceroute (or extended ping).
Rick
pkurdziel Tue, 02/17/2009 - 18:28
Sometimes you need to hit the X twice.
hold: ctrl+shift+6
release and press x x
