sticky resource not available ?
Feb 15th, 2009
I get the following error message then i try to configure sticky on an ACE:
Error: sticky resource not available
What is the problem ?
I have release "c6ace-t1k9-mz.A2_1_2.bin" and sticky should be supported.
ace-10/RGW_Front_servers(config)# sticky ip-netmask 255.255.255.255 address source RGW-FRONT
Ola Haglund
Overall Rating: 5 (1 ratings)
ciscocsoc Mon, 02/16/2009 - 00:23
Hi Ola,
By default sticky resources are not available. You need to go to the Admin context and define a new resource class with some stickiness. See Server LoadBalancing Guide Chapter 5 p8. For example:
resource-class RC1
limit-resource all minimum 0.00 maximum unlimited
limit-resource sticky minimum 10.00 maximum equal-to-min
Obviously the amount of sticky resource to allocate will depend on your application.
And then you need to make the context that needs stickiness a member of that resource class.
For example:
context Test
allocate-interface vlan 292-293
member RC1
Cathy
