Feb 16th, 2009
Can anyone tell me the difference between these two cables? Specificly, the number of pins, is it the same on RS232 side?
Thank you!
Paolo Bevilacqua Mon, 02/16/2009 - 02:48
Where did saw the CAB-SS-232FС-EXT code? it is not a cisco part number.
If need to connected routers back-to-back, suggest you buy pre-made cables off the popular auction site, that is cheap and effective.
Paolo Bevilacqua Mon, 02/16/2009 - 03:20
Strangely both google and cisco website sometime produces no results on that string.
Anyway I cannot find any pinout information.
