Not able to connect to ISDN Interface
Feb 16th, 2009
Hi Experts,
Need your help. I have configuration as below AND ALSO debug log at the bottom. NO matter what I have done , I still cant get it up.
- I have username/password of the other end router configured.
- I have the dialer protocol permit ip list
I can;t think off anything more. Need your advise.
Thanks!
CONFIGURATION of the routers :
interface Dialer10
ip address 172.2.24.202 255.255.255.252
ip nat inside
ip virtual-reassembly
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer idle-timeout 300
dialer enable-timeout 5
dialer string 64410114
dialer caller 64410114 callback
dialer load-threshold 200 either
dialer-group 1
no cdp enable
ppp authentication chap
ppp multilink
DEBUG LOGS at attached.
JamesLuther Mon, 02/16/2009 - 01:32
The debug logs show traffic going to Dialer15 however the config you've pasted is for Dialer10. Is the traffic being routed to the wrong dialer interface? If not please upload new debug of the correct traffic.
Giuseppe Larosa Mon, 02/16/2009 - 05:53
Hello Cindy,
you have configured ppp authentication chap.
you need to configure it on both the dialer and the physical interface
to see possible PPP problems use
debug ppp negotiation
debug ppp authentication
you need also a username remote-hostname password passw
the password must be the same on both sides
Hope to help
Giuseppe
