number of sessions cisco pix can support
Feb 16th, 2009
Hi all. I would like to know how many network sessions including vpn sessions a cisco pix 515e device can support. I don't seem to be able to find the specifications of pix515e from the internet. Understand its EOL already. Pls advise, thks in advance.
Overall Rating: 5 (2 ratings)
Syed Iftekhar Ahmed Mon, 02/16/2009 - 01:48
  • Blue, 1500 points or more
• Cleartext throughput: Up to 190 Mbps
• Concurrent connections: 130,000
• 168-bit 3DES IPSec VPN throughput: Up to 135 Mbps with VAC+ or 63 Mbps with VAC
• 128-bit AES IPSec VPN throughput: Up to 130 Mbps with VAC+
• 256-bit AES IPSec VPN throughput: Up to 130 Mbps with VAC+
• Simultaneous VPN tunnels: 2000
As per the following URL
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5708/ps5709/ps2030/ps4094/product_data_sheet09186a0080091b15.html
Syed Iftekhar Ahmed
donnie Mon, 02/16/2009 - 17:08
Hi lftekhar,
Thk you for the url link.
Can i confirm if 2000 simultaneous vpn tunnels refer to capability of supporting 2000 simultaneous vpn connections to the firewall?
Syed Iftekhar Ahmed Mon, 02/16/2009 - 17:26
As per my understanding value 2000 means that 515E supports up to 2000 Security Associations, NOT individual tunnels.
Easch IPSEC tunnel has 3 SAs (IKE SA, Tx SA, Rx SA). Depending on how elaborate your access-lists are, these can
use additional SA's.
In summary there are approximately 5 to 7 SA's per tunnel in a typical
configuration.
With assumption of 7 SAs per tunnel.The total comes to 285 unique tunnels.
Syed Iftekhar Ahmed
