Outbound Preview Dialer Agent allocation
Feb 16th, 2009
I have a query on Outbound Preview Dialer for UCCX
Requirement is for 20% of the Agents in a CSQ to handle calls initiated by the outbound dialer between 1100 and 1800 weekdays and there are 50 Agents in the CSQ. Hence the outbound dialer will allocate 10 Agents.
Questions
1) Will the outbound dialer wait until there are 10 Agents are not taking inbound calls?
2) Will the outbound dialer allocate different Agents at different times in the day? (during the 1100 to 1800 period)
Gurmakh
Aaron Harrison Tue, 02/17/2009 - 03:40
  • Community Spotlight Award,
    Member's Choice, May 2015
1) The % is a maximum usage of agents. The idea is that inbound and outbound calls are both dealt with by the same agents, so there should be some spare capacity for inbound calls at all times.
2) A max of 20% of agents will be used, but any agent in the CSQ could be used at any time.
Aaron
Please rate helpful posts...
gsidhu Wed, 02/18/2009 - 12:37
Hi Aaron,
Thanks for your response.
In 1) you say 'The idea is that inbound and outbound calls are both dealt with by the same agents' should that have been 'The idea is that inbound and outbound calls are both dealt by any of the Agents within the CSQ'.
It's the 'same agents' bit that I find confusing!
p-siadoua Wed, 07/07/2010 - 02:54
hi,
I am trying to configure outbound call on a  uccx 7, we need to change the allocation csq. The pourcentage still keep the default configuration (10%) we need to change it but it does not work.
Cdt
Aaron Harrison Wed, 07/07/2010 - 03:14
You don't need to hijack existing threads in addition to starting your own!
For completeness:
You need to do it like this:
1) CLick on a CSQ name in the 'Assigned CSQs' box
2) set the percentage to what you like
3) Click update
Then repeat for each CSQ that you wish to modify - it's set per-CSQ so you can have different percentages for each one. Confusing the first time you do it...
Aaron
p-siadoua Fri, 10/15/2010 - 06:46
thank you for your reply, i have also a problem with the agent selection for the outbound call.  In my configuration,  i have allocated 40% of my CSQ for outbound call, and sometimes when there is few agent for example 3 and if an agent  is available. An outbound  call is place  and the same agent always received the outbound calls as if there is no selection between agents available.
pamela
